If you have variant with LCD display – here you can download driver.
Important: To be able to boot clean Armbian mainline based u-boot / kernel experiences, you need to remove incompatible Petitboot loader that is shipped with the board.
Attach the device to a display and keyboard. Power on. Petitboot will load
From the Petitboot menu, go for “Exit to shell” and these commands to remove the Petitboot:
# flash_eraseall /dev/mtd0
# flash_eraseall /dev/mtd1
# flash_eraseall /dev/mtd2
# flash_eraseall /dev/mtd3
These commands can also be executed via a serial console, if you have an Odroid UART cable
This will make your SPI flash memory empty and would start from SD on next boot.
In case you want to put Petitboot back to the board, user these instructions.
Build Date: Jun 24, 2026
| Kali Linux | SHA | ASC | 572.7 MB | |||||||
| Home Assistant | SHA | ASC | 571.6 MB | |||||||
| OpenMediaVault | SHA | ASC | 433.4 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
1000tx 4 core 4GB 64bit Closed bootloader docker i2c sata spi flash usb3 wireguard Amlogic S905X3
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 323.1 MB | ||
| Resolute | XFCE | stable | 6.18.36 | SHA | ASC | 817.5 MB | |
