Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Resolute | Minimal / IOT | SHA | ASC | 292.3 MB | ||||||
| Resolute | Minimal / IOT | SHA | ASC | 294.5 MB | ||||||
| Kali Linux | SHA | ASC | 561.9 MB | |||||||
| Home Assistant | SHA | ASC | 564.9 MB | |||||||
| OpenMediaVault | SHA | ASC | 418.1 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 311.1 MB | ||
| Resolute | Gnome | stable | 6.18.36 | SHA | ASC | 1014.9 MB | |
