odroidm2
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.15, Size: 301.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 292.1 MB
Resolute Minimal / IOT SHA    ASC 299.5 MB
Debian Testing (Sid) Kali Linux SHA    ASC 562.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 561.3 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 421.6 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 318.9 MB
Resolute Gnome stable 6.18.36 SHA  ASC 998.2 MB
