odroidn2
Standard support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.18.33, Size: 1022.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 319.6 MB, Release date: Jun 24, 2026
  • some people are having troubles with booting with Petitboot loader. In case you have troubles too, you need to disable Petitboot by running fw_setenv skip_spiboot true in the command line of Petitboot
  • On modern kernels adding “video=HDMI-A-1:1920x1080M@60D” to boot /boot/armbianEnv.txt (extraargs=) should force HDMI to 1080p instead of the 4K native resolution.
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 322.1 MB
Debian Testing (Sid) Kali Linux SHA    ASC 576.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 570.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 426.3 MB
1000tx 2GB 4 core 4GB 6 core 64bit eMMC spi flash usb3 wireguard Amlogic S922X
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 321.5 MB
Resolute XFCE stable 6.18.36 SHA  ASC 817.3 MB
