odroidxu4
Standard support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.6.141, Size: 893.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.6.141, Size: 270.8 MB, Release date: Jun 24, 2026
For HC1 and HC2 we provide specially optimized config which you can enable via armbian-config -> system -> kernel -> select odroid configuration. This results in shorter boot time and lower consumption. Manualls – edit or create /boot/armbianEnv.txt and add: board_name=xu4 # or xu3, xu3, hc1
Overlay management via armbian-config is not supported. You need to edit /boot/boot.ini and add overlays manually. Look for a line:
setenv overlays "i2c0 i2c1 hktft-cs-ogst"
Here you add what you need. More you can find in /boot/dtb/ or /boot/dtb/overlays
Make sure to adjust path in
ext4load mmc 0:1 0x60000000 /boot/dtb/overlays/${overlay}.dtbo
accordingly.
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 260.2 MB
Dedicated applications images with Armbian Linux v6.6
Debian Testing (Sid) Kali Linux SHA    ASC 504 MB
Compatible
HC1 HC2 MC1
1000tx 2GB 32bit 8 core UASP docker eMMC usb3 Samsung Exynos 5422
Rolling releases images with Armbian Linux v6.6
Debian 14 (Forky) Minimal / IOT rolling 6.6.143 SHA  ASC 260.8 MB
Resolute XFCE stable 6.6.143 SHA  ASC 717 MB
