lime2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 726.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 270.9 MB, Release date: Jun 24, 2026
1000tx 1wire 2 core 32bit CAN UASP battery docker eMMC i2c i2s sata spi wireguard Allwinner A20
