Olimex Lime
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 737.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 267.9 MB, Release date: Jun 24, 2026
100tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s nand sata spi wireguard A20 Allwinner
