Olimex Teres
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 774.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 325.2 MB, Release date: Jun 24, 2026
The device has been tested to work without any known issues or limitations, please file a bug in the armbian tracker if you encounter any.
DRM_IOCTL_MODE_CREATE_DUMB failed
Linux 6.1.X introduced regression in mesa causing DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory resulting in various rendering issues and even failure to perform first installation, see mesa/mesa#8198 for tracking.
The issue has been addressed in mesa/mesa/commit/c426e5677f36c3b0b8e8ea199ed4f2c7fad06d47
and evidently shipped in Linux 6.2.X.
Merge request armbian/os#45 was submitted to use edge kernel to workaround this issue, may introduce issues with armbian-firmware causing display to not work as cause it not yet fully understood, if that happens utilize the debuging cable and invoke:
$ picocom /dev/ttyUSB0 -b BAUM # Opens serial console on the laptop
The BAUM is by default 115200 as specified in https://github.com/armbian/build/blob/main/config/boards/olimex-teres-a64.conf or your SERIALCON, if you specified it in your installation, note that BAUM beyond 115200 is not recommended.
To install armbian-config (if it’s not installed already) and update the firmware, the display should then work again after reboot.
If you encounter this issue, then please inform @kreyren about it.
2GB 4 core 64bit battery bluetooth docker eMMC wifi wireguard Allwinner A64
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
