Orangepi2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 738.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 279.8 MB, Release date: Jun 24, 2026
100tx 1wire 32bit 4 core CAN UASP docker i2c i2s spi wifi wireguard Allwinner H3
