orangepione
Standard support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.18.33, Size: 910.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 269.3 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 273.1 MB
Debian Testing (Sid) Kali Linux SHA    ASC 507.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 510.4 MB
100tx 1wire 32bit 4 core CAN UASP docker i2c spi wireguard Allwinner H3
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 271 MB
Resolute XFCE stable 6.18.36 SHA  ASC 726.1 MB
