orangepipcplus
Community maintained
Desktop
Armbian 26.2.0-trunk.792 XFCE
Kernel: 6.18.24, Size: 837.8 MB, Release date: Apr 25, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.792 Minimal / IOT
Kernel: 6.18.24, Size: 268.8 MB, Release date: Apr 25, 2026
100tx 1wire 32bit 4 core CAN UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H3
