Orange Pi PC2
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.74, Size: 278.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 256.8 MB
Resolute Minimal / IOT SHA    ASC 280.6 MB
Debian Testing (Sid) Kali Linux SHA    ASC 548.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 546.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 385.1 MB
1000tx 4 core 64bit UASP docker i2c spi spi flash wireguard Allwinner H5
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 281.4 MB
Resolute XFCE stable 6.18.36 SHA  ASC 778.2 MB
