orangepiprime
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 756.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 281.1 MB, Release date: Jun 24, 2026
1000tx 1wire 2GB 32bit 4 core 64bit UASP docker i2c spi wifi wireguard Allwinner H5
