Orangepi Zero plus 2 H5
Community maintained
Minimal
Kernel: 6.18.35, Size: 266.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
4 core 64bit bluetooth docker eMMC i2c spi spi flash wifi wireguard Allwinner H5
