orangepi-r1plus
Minimal
Kernel: 6.18.35, Size: 293.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
  • There may be a known issue that could affect this board on some IPv4 only networks. Symptoms are variable, from intermittent drop-outs and slow-downs to total loss of one NIC or total loss of networking. The issue can be completely eliminated by disabling IPv6. Don’t try to do this through armbian-config this method does not work. IPv6 must be disabled by adding a line extraargs="ipv6.disable=1" to /boot/armbianEnv.txt
1000tx 4 core 64bit UASP spi flash usb-c wireguard Rockchip RK3328
