Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 769.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 266.5 MB, Release date: Jun 24, 2026
  • USB3 sometimes doesn’t detect high-speed devices properly
1000tx 2GB 4 core 64bit bluetooth docker eMMC i2c i2s spi flash usb3 wifi wireguard H6 Allwinner
