Pinebook A64
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 752.1 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 265.9 MB, Release date: Jun 24, 2026
  • Supported 720 and 1080p model,
  • DVFS, battery and brightness control,
  • MALI with opensource Lima drivers,
  • Chromium web-dl enabled,
  • not enabled or not tested: suspend/resume
2GB 4 core 64bit battery bluetooth eMMC wifi wireguard Allwinner A64
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
