Notebook
Community maintained
x86_64 via UEFI/BIOS for generic virtual board
Usage: Use this board to run armbian on a virtualized environment (eg: QEMU/KVM)
Differences with the ‘uefi-x86’ board:
  • support kernel boot messages on graphical and console/serial devices
  • support prompt on graphical/console devices
  • patches targeting virtualized env on x86 should be added here – when it make sense
Generic aarch64
