radxa-cubie-a5e
Community maintained Staging
Desktop
Armbian 26.2.0-trunk.792 XFCE
Kernel: 7.0.1, Size: 897.9 MB, Release date: Apr 25, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.792 Minimal / IOT
Kernel: 7.0.1, Size: 327.4 MB, Release date: Apr 25, 2026
A527 Allwinner
