Standard support
Minimal
Armbian 26.2.4 Minimal / IOT
Kernel: 6.18.2, Size: 884.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Armbian 26.02 is tested for the latest UEFI firmware (flat_build_wp_260120)  that is available for this board.
For flashing the (extracted) armbian image to UFS storage you can use the same edl-ng tool from flashing the firmware with this command:
./edl-ng --loader prog_firehose_ddr.elf --memory UFS write-sector 0 *.img
Bugfixes in 26.02 – Branch: Current
  • Audio Output
  • Booting with the latest BIOS (+DualBoot with Windows 11 on Arm) now possible
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.7 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.9 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 2 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 887.4 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 893.6 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 885 MB
Snapdragon
