| Armbian 26.2.1 Trixie Minimal testing: |
Armbian 26.2.1 Noble Minimal testing: |
Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Resolute | Minimal / IOT | SHA | ASC | 289.6 MB | ||||||
| Minimal / IOT | SHA | ASC | 290.8 MB | |||||||
| Kali Linux | SHA | ASC | 549.5 MB | |||||||
| Home Assistant | SHA | ASC | 537.2 MB | |||||||
| OpenMediaVault | SHA | ASC | 425.7 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 318.1 MB | ||
| Resolute | Minimal / IOT | stable | 6.18.36 | SHA | ASC | 316.8 MB | |
