Radxa E54C
Standard support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 289 MB, Release date: Jun 24, 2026
Armbian 26.2.1
Vendor Trixie Minimal testing:
Armbian 26.2.1 Vendor Noble Gnome
Desktop testing:
  • Boot okay, from sdcard
  • Reboot okay, from sdcard
  • Shutdown okay
  • Debug port okay, Speed: 1500000
  • USB2 port 1 is okay
  • USB2 port 2 is okay
  • USB3 port is okay
  • Gigabit Ethernet LAN1 is okay, Iperf3 ~960 Mbit/s
  • Gigabit Ethernet LAN2 is okay, Iperf3 ~960 Mbit/s
  • Gigabit Ethernet LAN3 is okay, Iperf3 ~960 Mbit/s
  • Gigabit Ethernet WAN is okay, Iperf3 ~960 Mbit/s
  • Shutdown okay
  • USB3 port is okay
  • HDMI video is okay
  • HDMI audio is okay
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 288.9 MB
Debian Testing (Sid) Kali Linux SHA    ASC 546.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 531.4 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 408.7 MB
Rockchip RK3582
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 291.5 MB
Resolute Gnome stable 6.1.115 SHA  ASC 955.8 MB
