Nio-12L-Side-View
Standard support
Minimal
Armbian 26.2.4 Minimal / IOT
Kernel: 6.19.8, Size: 788.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
How to install
Radxa-Nio-12L uses EFI Boot via Grub with DeviceTree. To make use of it follow this Guide from Collabora to flash Uboot onto the UFS storage. Then you can flash one of the provided images onto a SD-Card and power on the SBC which will automatically boot into Armbian. Keep in mind the Boot order has UFS at first place so you need to erase any OS you have on on UFS to boot from a SD Card.
Q&A for Genio-Family:
  • Can I boot from UFS?
    • Yes just make sure to use the Armbian image with the UFS extension as these are partioned with 4096 sector size instead of the 512 used commonly for SD-Card / NVMe / etc.
  • Which kernels are available?
    • We’re making use of Collabora’s mediatek-next branch which is based on mainline Linux.
  • XYZ is not working.
    • Check this support matrix to see if that feature has been implemented already.
Bleeding edge images with Armbian Linux v6.19
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 741.6 KB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 775.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 98.6 KB
Ubuntu 24.04 (Noble) Cinnamon SHA    ASC 741.6 KB
Ubuntu 24.04 (Noble) Cinnamon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) Cinnamon SHA    ASC 98.6 KB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 741.6 KB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 98.6 KB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 741.6 KB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.9 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 98.6 KB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 771.3 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 741.6 KB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 788.4 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 98.6 KB
Resolute Minimal / IOT SHA    ASC 741.6 KB
Resolute Minimal / IOT SHA    ASC 780.1 MB
Resolute Minimal / IOT SHA    ASC 98.6 KB
Resolute Minimal / IOT SHA    ASC 776 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Dedicated applications images with Armbian Linux v6.19
Debian Testing (Sid) SHA    ASC 752 KB
Debian Testing (Sid) Kali Linux SHA    ASC 1.2 GB
Debian Testing (Sid) SHA    ASC 98.6 KB
Debian 13 (Trixie) SHA    ASC 752 KB
Debian 13 (Trixie) Home Assistant SHA    ASC 1.3 GB
Debian 13 (Trixie) SHA    ASC 98.6 KB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 752 KB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 899.5 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 98.6 KB
Debian 13 (Trixie) OpenHab SHA    ASC 1.9 GB
MT8395
Rolling releases images with Armbian Linux v6.19
Debian 14 (Forky) Minimal / IOT rolling 6.19.8 SHA  ASC 741.6 KB
Debian 14 (Forky) Minimal / IOT rolling 6.19.8 SHA  ASC 813.5 MB
Debian 14 (Forky) Minimal / IOT rolling 6.19.8 SHA  ASC 98.6 KB
Resolute Gnome stable 6.19.8 SHA  ASC 741.6 KB
Resolute Gnome stable 6.19.8 SHA  ASC 1.5 GB
Resolute Gnome stable 6.19.8 SHA  ASC 98.6 KB
