Radxa Rock 4D
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.19.5, Size: 367 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
  • Installation to NVME or USB is done via standard armbian install utility (sudo armbian-install). Make sure to generate partitions and format them before start.
  • For UFS ready images use an image with the Extension UFS and flash it directly either via an USB-Adapter or via `rkdeveloptool`. See this Docs page for more information on how to flash Rockchip boards via Maskrom mode.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 313.1 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 346.3 MB
Bleeding edge images with Armbian Linux v6.19
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 357.4 MB
Resolute Minimal / IOT SHA    ASC 354.8 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Debian Testing (Sid) Kali Linux SHA    ASC 573.4 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 544 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 490.6 MB
Rockchip
Rolling releases images with Armbian Linux v7.1
Debian 14 (Forky) Minimal / IOT rolling 7.1.1 SHA  ASC 389.8 MB
Resolute Gnome stable 7.1.1 SHA  ASC 1004.6 MB
