radxa-rock-5c
Standard support Platinum support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 343.3 MB, Release date: Jun 24, 2026
Armbian 26.2.1
Trixie Minimal / IOT testing:
Armbian 26.2.1 Noble
Gnome testing:
  • Boot okay, from sdcard
  • HDMI video (text) is okay
  • Audio not tested on minimal image
  • USB2 ports are okay
  • USB3 ports are okay
  • Gigabit Ethernet is okay, Iperf3 ~940 Mbit/s
  • Wireless okay, Iperf3 ~180 Mbit/s
  • Reboot and shutdown okay
  • HDMI video is okay
  • HDMI audio is okay
  • Jack audio headphone out is okay
  • Jack audio mic in is okay
  • Gigabit Ethernet is okay, Iperf3 ~950Mbit/s
  • Wireless okay, Iperf3 ~174 Mbit/s
  • Bluetooth okay
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Resolute Minimal / IOT SHA    ASC 388.1 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 388.1 MB
Resolute Minimal / IOT SHA    ASC 344 MB
Debian Testing (Sid) Kali Linux SHA    ASC 565.3 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 569.3 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 456.8 MB
RK3588 Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 361.3 MB
Resolute Gnome stable 6.1.115 SHA  ASC 969.1 MB
