Radxa Rock 5T
Standard support Platinum support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 288.7 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 315.5 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 303.9 MB
Resolute Minimal / IOT SHA    ASC 289.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 536.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 549.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 383.7 MB
RK3588 Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 279.6 MB
Resolute Gnome stable 6.1.115 SHA  ASC 958.2 MB
