Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 361.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 364 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 373.1 MB
Resolute Minimal / IOT SHA    ASC 383.8 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 342.8 MB
Resolute Minimal / IOT SHA    ASC 356.9 MB
Debian Testing (Sid) Kali Linux SHA    ASC 572.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 557.4 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 453.2 MB
Rockchip RK3566
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 355.9 MB
Resolute Gnome stable 6.1.115 SHA  ASC 979.7 MB
