radxa-zero2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 820 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 301.7 MB, Release date: Jun 24, 2026
4GB 6 core 64bit bluetooth docker eMMC i2c spi usb-c usb3 wifi wireguard Amlogic A311D
