Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 360.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 343.9 MB
Resolute Minimal / IOT SHA    ASC 352 MB
Debian Testing (Sid) Kali Linux SHA    ASC 537.4 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 546.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 460.4 MB
Rockchip RK3528A
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 348.7 MB
Resolute Gnome stable 6.1.115 SHA  ASC 978.9 MB
