rock3a
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.8, Size: 297.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 293 MB
Resolute Minimal / IOT SHA    ASC 314.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 255.3 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 271.9 MB
Resolute Minimal / IOT SHA    ASC 280.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 569.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 569.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 430 MB
1000tx 2GB 4 core 4GB 64bit 8GB UASP bluetooth docker eMMC i2c m2 pci spi flash usb-c usb3 wireguard Rockchip RK3568
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 319.5 MB
Resolute Gnome stable 6.18.36 SHA  ASC 994.7 MB
