rock5bplus
Standard support Platinum support
Desktop
Armbian 26.2.6 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.6 Minimal / IOT
Kernel: 6.1.115, Size: 289.9 MB, Release date: Jun 24, 2026
Ubuntu Noble 24.11.1 GNOME Testing: Rolling Release (25.2.x) Testing:
  • Kernel Vendor 6.1.75
  • Boot ok, from emmc and nvme
  • HDMI ok, boot splash screen shows up
  • USB-C DP + HDMI at the same time wonky (alone both work as intended)
  • USB2 and USB3 ok
  • 2.5GbE Ethernet ok
  • WiFi ok
  • Bluetooth “Failed to set mode: Failed (0x03)”
  • Analog audio codec is ok
  • Reboot and shutdown work as intended
  • 4K YouTube Playback fine with Mesa-VPU extension
  • Kernel Vendor 6.1.84
  • Everything from 6.1.75
  • Fixed Bluetooth search & pairing
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 298.5 MB
Resolute Minimal / IOT SHA    ASC 317 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 315.6 MB
Resolute Minimal / IOT SHA    ASC 287.7 MB
Resolute Minimal / IOT SHA    ASC 277.5 MB
Debian Testing (Sid) Kali Linux SHA    ASC 543 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 541.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 406.5 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 283.3 MB
Resolute Gnome stable 6.1.115 SHA  ASC 969.9 MB
