- If your RockPi-S is equipped a large enough SDNAND, you may flash an OS image directly to this internal flash as follows:
- Build Linux x86 binary rkdeveloptool (sources) on host
- Remove any SDcard
- Plug the USB-C port into your computer
- Hold down MASKROM button while you…
- Power on or press the RESET button to enter flash mode
- Release the MASKROM button after 2 seconds
Next, run these host commands to flash the internal SDnand:-
- sudo rkdeveloptool db rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin
- #await output: Downloading bootloader succeeded.
- sudo rkdeveloptool wl 0 /path/to/uncompressed_armbian_image
- #await output: Write LBA from file (100%)
- sudo rkdeveloptool rd
- #outputs: Reset Device OK.
(check official step by step instructions)
- Holding the MASKROM button during reset prevents booting from internal the SDNAND.
- But, the board will always boot from the SD Card, if it finds a valid image there.
- Kernel serial console is on UART0. [some older images have their console on UART2]
- The serial console operates at 1.5Mbaud with 8 data, 1 stop, and no parity bits.
- Black(left)=GND, White(center)=TxD, Green(right)=RxD
If you have a board with the -B version of the SOC, you may add the following line to your /boot/armbianEnv.txt file to allow operation at 1.3ghz:
overlays=b@1.3ghz
If you have a board with the BS version of the SOC, you should add the following line to your /boot/armbianEnv.txt file to tune for the newer “BS” silicon and run at 1.3ghz:
overlays=bs bs@1.3ghz
Note that the B version SOC is more common. It is labeled RK330B.
The BS version chip should be labeled RK3308B-S.
Refer to /boot/dtb/rockchip/overlay/README.rockchip-overlays for more information.
Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Minimal / IOT | SHA | ASC | 316.2 MB | |||||||
| Kali Linux | SHA | ASC | 552.9 MB | |||||||
| Home Assistant | SHA | ASC | 541.8 MB | |||||||
| OpenMediaVault | SHA | ASC | 408.1 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
100tx 4 core 64bit bluetooth docker eMMC i2c i2s spi usb-c wifi wireguard Rockchip RK3308
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 318.7 MB | ||
| Resolute | Minimal / IOT | stable | 6.18.36 | SHA | ASC | 291.3 MB | |
