The AM62B starter kit (SK) evaluation module (EVM) is a stand-alone test and development platform built around the AM62x system-on-a-chip (SoC). AM62x processors are comprised of a quad-core 64-bit Arm®-Cortex®-A53 microprocessor, single-core Arm Cortex-R5F microcontroller (MCU) and an Arm Cortex-M4F MCU.
SK-AM62B is the newest version of SK-AM62 and includes high-security field-securable (HS-FS) silicon to customize keys and encryption for security applications.
SK-AM62B allows the user to experience a dual-display feature through high-definition multimedia interface (HDMI) [over dots per inch (DPI)] and low-voltage differential signaling (LVDS), as well as industrial communication solutions using serial, Ethernet, USB and other interfaces.
SK-AM62B can be used for display applications (e.g., human machine interface (HMI) and control panel) with either an HDMI display or an external LVDS panel, up to 2K resolution. Its powerful Arm performance, up to quad-A53 at 1.4 GHz with rich industrial interfaces, offers good control and communication capabilities for a wide range of applications, such as programmable logic controllers (PLC), automation control or a monitor/supervisor system.
Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Gnome | SHA | ASC | 1.3 GB | |||||||
| KDE Neon | SHA | ASC | 1.4 GB | |||||||
| * Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. | ||||||||||
| Minimal / IOT | SHA | ASC | 290.7 MB | |||||||
| Resolute | Minimal / IOT | SHA | ASC | 319.5 MB | ||||||
| Kali Linux | SHA | ASC | 517.2 MB | |||||||
| Home Assistant | SHA | ASC | 522.8 MB | |||||||
| OpenMediaVault | SHA | ASC | 433.4 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
