sk-am64b
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.57, Size: 298.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.5 Minimal / IOT
Kernel: 6.18.13, Size: 318.1 MB, Release date: Jun 24, 2026
The AM64B starter kit (SK) is a low-cost stand-alone test and development platform based on the Sitara™ AM6442 processor that is ideal for accelerating the prototype phase of your next design. The kit includes wired (Ethernet) and wireless (2.4GHz and 5GHz) connectivity, three expansion headers, multiple boot options and flexible debug.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 286.9 MB
Debian Testing (Sid) Kali Linux SHA    ASC 512.4 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 502.5 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 424.3 MB
Sitara AM64x
Debian 14 (Forky) Minimal / IOT rolling 6.18.13 SHA  ASC 326.2 MB
Resolute Minimal / IOT stable 6.18.13 SHA  ASC 318.3 MB
