Standard support
Minimal
Armbian 25.11.1 Minimal / IOT
Kernel: 6.12.43, Size: 295.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
The SK-AM69 Starter Kit/Evaluation Module (EVM) is based on the AM69x AI vision processor which includes an image signal processor (ISP) supporting up to 1440MP/s, 32 tera-operations-per-second (TOPS) AI accelerator, eight 64-bit Arm®-Cortex® A72 microprocessor, and H.264/H.265 video encode/decode. The SK-AM69x is an ideal choice for machine vision, traffic monitoring, retail automation, and factory automation.
The starter kit also includes two RPI 22-Pin CSI connector and two MIPI CSI-2 40-Pin expansion connectors for up to 12 cameras, making it suitable for a variety of embedded vision and AI applications on the edge.  Our ISP can handle different lighting conditions in video streams by using HDR encoding for camera support. The TI deep-learning accelerator enables classification and object detection at low latency and high frame rate.
Features
  • Performance: AM69 processor enables 32 TOPS deep-learning performance and hardware-accelerated edge AI at low power
  • Camera interfaces: three CSI-2 ports compatible with Raspberry Pi or a high-speed 40-pin Samtec camera connector allowing up to twelve cameras (requires multi camera hub)
  • Connectivity: three SuperSpeed USB Type A ports, one SuperSpeed USB Type C port, one ethernet port, one M.2 key E connector and one M.2 key M connector, four CAN-FD interfaces, four UART terminals over one USB bridge
  • Memoy: four DRAM, LPDDR4‐4266, 32 gigabytes total memory, support for inline ECC
  • Display: DisplayPort with up to 4K resolution with MST support and 1080 HDMI
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 277.8 MB
Resolute Minimal / IOT SHA    ASC 318.8 MB
Debian Testing (Sid) Kali Linux SHA    ASC 514.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 521 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 433.1 MB
