Standard support
Bring smart cameras, robots and intelligent machines to life with the TDA4VM processor starter kit. With a fast setup process and an assortment of foundational demos and tutorials, you can start prototyping a vision-based application in less than an hour. The kit enables 8 trillion operations per second (TOPS) of deep learning performance and hardware-accelerated edge AI processing without any hand-tooling. You can unleash high-speed AI in your embedded application only using Linux and industry standard APIs (TensorFlow Lite, ONNX Runtime, TVM, GStreamer, Docker, ROS, OpenGL ES).
Features
  • PerformanceTDA4VM processor enables 8 TOPS deep learning performance and hardware-accelerated edge AI at low power
  • Camera interfaces—two CSI-2 ports compatible with Raspberry Pi and a high-speed 40-pin Semtec camera connector connecting up to eight cameras (requires TIDA-01413 sensor fusion add-on card)
  • Connectivity—three USB 3.0 Type A ports, one USB 3.0 Type C ports, one ethernet port, one M.2 Key E connector and one M.2 Key M connector, four CAN-FD interfaces, four UART terminals over one USB bridge
  • Memory—DRAM, LPDDR4‐4266, 4 gigabytes total memory, support for inline ECC
  • Display—DisplayPort with up to 4K resolution with MST support and 1080 HDMI
Build Date: Jun 24, 2026
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.2 GB
Server images with Armbian Linux v6.1
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 414.4 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 208.2 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 204.4 MB
Resolute Minimal / IOT SHA    ASC 315.8 MB
Debian Testing (Sid) Kali Linux SHA    ASC 517.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 518.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 488.4 MB
