Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Minimal / IOT | SHA | ASC | 894.1 MB | |||||||
Cloud Images images with Armbian Linux v6.18
| Distro | Variant | Type | Torrent | Integrity | Size | |||||
| Minimal / IOT | SHA | ASC | 175.8 MB | |||||||
| Minimal / IOT | (QCOW2) | SHA | ASC | 175 MB | ||||||
| Minimal / IOT | SHA | ASC | 174.2 MB | |||||||
| Resolute | Minimal / IOT | SHA | ASC | 210.8 MB | ||||||
| Resolute | Minimal / IOT | (QCOW2) | SHA | ASC | 208.4 MB | |||||
| Resolute | Minimal / IOT | SHA | ASC | 209.3 MB | ||||||
| Minimal / IOT | SHA | ASC | 169.7 MB | |||||||
| Minimal / IOT | (QCOW2) | SHA | ASC | 170.5 MB | ||||||
| Minimal / IOT | (QCOW2) | SHA | ASC | 1.9 GB | ||||||
| Minimal / IOT | SHA | ASC | 1.9 GB | |||||||
| Resolute | Minimal / IOT | (QCOW2) | SHA | ASC | 1.9 GB | |||||
| Resolute | Minimal / IOT | SHA | ASC | 1.9 GB | ||||||
Bleeding edge images with Armbian Linux v7.0
| Resolute | Minimal / IOT | SHA | ASC | 885 MB | ||||||
| Resolute | Cinnamon | SHA | ASC | 1.9 GB | ||||||
| Resolute | I3-wm | SHA | ASC | 1.7 GB | ||||||
| Resolute | KDE Plasma | SHA | ASC | 2 GB | ||||||
| Resolute | Mate | SHA | ASC | 1.7 GB | ||||||
| Resolute | XFCE | SHA | ASC | 1.6 GB | ||||||
| Minimal / IOT | SHA | ASC | 899.4 MB | |||||||
| * Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. | |||||||||
| Kali Linux | SHA | ASC | 1.3 GB | |||||||
| Home Assistant | SHA | ASC | 1.2 GB | |||||||
| OpenMediaVault | SHA | ASC | 985.7 MB | |||||||
| OpenHab | SHA | ASC | 1.9 GB | |||||||
Compatible
10000tx 1000tx 100tx 16GB 1wire 2 core 2500tx 2GB 32bit 4 core 4GB 6 core 64bit 8 core 8GB CAN ECC SPDIF UASP battery bluetooth docker eMMC esata i2c i2s m2 mpci msata nand pci sata sfp spi spi flash switch usb-c usb3 wifi wireguard
- join community forums
| Minimal / IOT (Hyperv) | rolling | 6.18.36 | SHA | ASC | 1.3 GB | ||
| Minimal / IOT (QCOW2) | rolling | 6.18.36 | SHA | ASC | 1.2 GB | ||
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 925.2 MB | ||
| Resolute | Minimal / IOT (Hyperv) | stable | 6.18.36 | SHA | ASC | 1.2 GB | |
| Resolute | Minimal / IOT (QCOW2) | stable | 6.18.36 | SHA | ASC | 1.1 GB | |
| Resolute | Gnome | stable | 6.18.36 | SHA | ASC | 1.6 GB | |
