Notebook
Standard support
Desktop
Armbian 26.5.1 Gnome
Kernel: 7.0.9, Size: 2.5 GB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.32, Size: 932.5 MB, Release date: Jun 24, 2026
Why Does Armbian Provide x86 Builds?
Key Benefits:
  • Delivers the embedded Linux experience and development environment to standard x86 hardware
  • Focuses on broad hardware compatibility and robust device driver support
  • Optimized for fast development cycles, automated testing, and CI/CD workflows
  • Ubuntu-based builds are free from proprietary Canonical services and telemetry
  • Offers a ready-to-use live OS image, ideal for custom Linux OS prototyping and deployment
  • Enables cross-platform development and consistency across ARM and x86 environments
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 935.3 MB
Resolute Minimal / IOT SHA    ASC 934.5 MB
Cloud Images images with Armbian Linux v6.18
Distro Variant Type Torrent Integrity Size
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 187.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) SHA    ASC 185.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 185.6 MB
Resolute Minimal / IOT SHA    ASC 228.7 MB
Resolute Minimal / IOT (QCOW2) SHA    ASC 228.7 MB
Resolute Minimal / IOT SHA    ASC 228.9 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 183.4 MB
Debian 13 (Trixie) Minimal / IOT (QCOW2) SHA    ASC 184.3 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) SHA    ASC 1.9 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 1.9 GB
Resolute Minimal / IOT (QCOW2) SHA    ASC 2 GB
Resolute Minimal / IOT SHA    ASC 2 GB
Debian 13 (Trixie) Minimal / IOT (QCOW2) SHA    ASC 1.9 GB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 2 GB
Bleeding edge images with Armbian Linux v7.0
Resolute Cinnamon SHA    ASC 2.7 GB
Resolute I3-wm SHA    ASC 2.4 GB
Resolute KDE Plasma SHA    ASC 2.8 GB
Resolute Mate SHA    ASC 2.5 GB
Resolute XFCE SHA    ASC 2.3 GB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 925.9 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Debian Testing (Sid) Kali Linux SHA    ASC 1.3 GB
Debian 13 (Trixie) Home Assistant SHA    ASC 1.3 GB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 1 GB
Debian 13 (Trixie) OpenHab SHA    ASC 2 GB
Compatible
Khadas MIND
Debian 14 (Forky) Minimal / IOT (Hyperv) rolling 6.18.36 SHA  ASC 1.3 GB
Debian 14 (Forky) Minimal / IOT (QCOW2) rolling 6.18.36 SHA  ASC 1.1 GB
Resolute Minimal / IOT (Hyperv) stable 6.18.36 SHA  ASC 1.2 GB
Resolute Minimal / IOT (QCOW2) stable 6.18.36 SHA  ASC 1.1 GB
