Standard support
Make sure to check flashing guide!
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 45.3 MB
Ubuntu 24.04 (Noble) Gnome (BOE) SHA    ASC 45.3 MB
Ubuntu 24.04 (Noble) Gnome (CSOT) SHA    ASC 45.3 MB
Ubuntu 24.04 (Noble) Gnome (rootfs) SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 46.4 MB
Ubuntu 24.04 (Noble) KDE Neon (BOE) SHA    ASC 46.4 MB
Ubuntu 24.04 (Noble) KDE Neon (CSOT) SHA    ASC 46.4 MB
Ubuntu 24.04 (Noble) KDE Neon (rootfs) SHA    ASC 1.9 GB
Snapdragon SM8250
