orangepir1-pluslts
Community maintained
Minimal
Armbian 26.2.0-trunk.792 Minimal / IOT
Kernel: 6.18.24, Size: 291.5 MB, Release date: Apr 25, 2026
SHA hash | PGP signature
Community user space packages
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
  • Images for non LTS version can be downloaded here
  • There is currently a known issue that may affect this board on some IPv4 only networks. Symptoms are variable, from intermittent drop-outs and slow-downs to total loss of one NIC or total loss of networking. The issue can be completely eliminated by disabling IPv6. Don’t try to do this through armbian-config as this method does not work. IPv6 must be disabled by adding a line extraargs="ipv6.disable=1" to /boot/armbianEnv.txt
  • Device tree overlays to enable uart1 and i2c0 are available in Armbian 23.02.
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Use armbian-config utility to adjust your system settings
Specifications
1000tx 4 core 64bit UASP usb-c wireguard Rockchip RK3328
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
