orangepir1-pluslts
Community maintained
Minimal
Kernel: 6.18.35, Size: 296.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
  • Images for non LTS version can be downloaded here
  • There is currently a known issue that may affect this board on some IPv4 only networks. Symptoms are variable, from intermittent drop-outs and slow-downs to total loss of one NIC or total loss of networking. The issue can be completely eliminated by disabling IPv6. Don’t try to do this through armbian-config as this method does not work. IPv6 must be disabled by adding a line extraargs="ipv6.disable=1" to /boot/armbianEnv.txt
  • Device tree overlays to enable uart1 and i2c0 are available in Armbian 23.02.
1000tx 4 core 64bit UASP usb-c wireguard Rockchip RK3328
