devterma06
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 814.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 315.2 MB, Release date: Jun 24, 2026
2GB 4GB 6 core 64bit battery bluetooth usb-c wifi Rockchip RK3399
