Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 795.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 302.2 MB, Release date: Jun 24, 2026
1000tx 1wire 4GB 6 core 64bit UASP battery bluetooth docker eMMC i2c i2s m2 pci spi spi flash usb-c usb3 wifi wireguard Rockchip RK3399
