nanopct4
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 815.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 308.6 MB, Release date: Jun 24, 2026
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you want to boot from your SD card you need to hold boot button while powering up/resetting
1000tx 4GB 6 core 64bit UASP bluetooth docker eMMC i2c i2s m2 usb-c usb3 wifi Rockchip RK3399
