nanopim4
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 809.4 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 317.6 MB, Release date: Jun 24, 2026
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
  • Powering related troubles are possible since USB Type-C is not PD-compliant
1000tx 1wire 2GB 4GB 6 core 64bit UASP bluetooth docker eMMC i2c usb-c usb3 wifi wireguard Rockchip RK3399
