nanopineo4
Community maintained
Desktop
Armbian 26.2.0-trunk.792 XFCE
Kernel: 6.18.24, Size: 928.2 MB, Release date: Apr 25, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.792 Minimal / IOT
Kernel: 6.18.24, Size: 312.9 MB, Release date: Apr 25, 2026
1000tx 1wire 2GB 6 core 64bit UASP bluetooth docker eMMC i2c usb3 wifi RK3399 Rockchip
