Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 813.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 293.1 MB, Release date: Jun 24, 2026
  • UART has unusual speed: 1500000
  • Make sure to add large heatsink
  • Powering related troubles are possible since USB Type-C is not PD-compliant
1000tx 4GB 6 core 64bit UASP bluetooth docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
