orangepi-rk3399
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 803.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 297 MB, Release date: Jun 24, 2026
  • UART has unusual speed: 1500000
  • boot from SD card is possible by shorting TP50265 to the ground and powering the board. After Armbian boots up, you can overwrite eMMC. You need to do this procedure only once or in case you totally brick your system.
  • once you have Armbian booting from eMMC, you can boot SD card in more simple manner: stop booting from UART console and execute those commands: setenv devnum 1 followed by run mmc_boot
  • you need to use EXPERT="yes" to build kernel or images.
1000tx 2GB 4GB 6 core 64bit bluetooth docker eMMC usb-c usb3 wifi wireguard Rockchip RK3399
