pinebookpro
Community maintained
Desktop
Armbian 26.5.1 Gnome
Kernel: 7.0.9, Size: 1.7 GB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.32, Size: 898.2 MB, Release date: Jun 24, 2026
    • Some eMMC modules might not work well.
    • Recent batch (since mid-2022) seem to have shipped with a different bootloader configuration, some times preventing booting from SD card and/or eMMC. Until a proper fix can be implemented, the recommended workaround is to install a bootloader to SPI. Further details and instructions can be found in this forum thread.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 894.1 MB
Cloud Images images with Armbian Linux v6.18
Distro Variant Type Torrent Integrity Size
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 175.8 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) SHA    ASC 175 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 174.2 MB
Resolute Minimal / IOT SHA    ASC 210.8 MB
Resolute Minimal / IOT (QCOW2) SHA    ASC 208.4 MB
Resolute Minimal / IOT SHA    ASC 209.3 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 169.7 MB
Debian 13 (Trixie) Minimal / IOT (QCOW2) SHA    ASC 170.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) SHA    ASC 1.9 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 1.9 GB
Resolute Minimal / IOT (QCOW2) SHA    ASC 1.9 GB
Resolute Minimal / IOT SHA    ASC 1.9 GB
Debian 13 (Trixie) Minimal / IOT (QCOW2) SHA    ASC 1.9 GB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 1.9 GB
Bleeding edge images with Armbian Linux v7.0
Resolute Minimal / IOT SHA    ASC 885 MB
Resolute Cinnamon SHA    ASC 1.9 GB
Resolute I3-wm SHA    ASC 1.7 GB
Resolute KDE Plasma SHA    ASC 2 GB
Resolute Mate SHA    ASC 1.7 GB
Resolute XFCE SHA    ASC 1.6 GB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 899.4 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Debian Testing (Sid) Kali Linux SHA    ASC 1.3 GB
Debian 13 (Trixie) Home Assistant SHA    ASC 1.2 GB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 985.7 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.9 GB
4GB 6 core 64bit battery bluetooth docker eMMC usb-c usb3 wifi wireguard Rockchip RK3399
Debian 14 (Forky) Minimal / IOT (Hyperv) rolling 6.18.36 SHA  ASC 1.3 GB
Debian 14 (Forky) Minimal / IOT (QCOW2) rolling 6.18.36 SHA  ASC 1.2 GB
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 925.2 MB
Resolute Minimal / IOT (Hyperv) stable 6.18.36 SHA  ASC 1.2 GB
Resolute Minimal / IOT (QCOW2) stable 6.18.36 SHA  ASC 1.1 GB
Resolute Gnome stable 6.18.36 SHA  ASC 1.6 GB
