sweet-potato
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.8, Size: 303.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 26.2.5 XFCE
Kernel: 6.18.24, Size: 1003.9 MB, Release date: Jun 24, 2026
This device could also run standard UEFI image.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 293 MB
Resolute Minimal / IOT SHA    ASC 319 MB
Debian Testing (Sid) Kali Linux SHA    ASC 572.6 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 554.5 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 402 MB
Amlogic S905X
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 321.3 MB
Resolute XFCE stable 6.18.36 SHA  ASC 808 MB
